Monostable multivibrator
Discussion in 'Electronic Basics' started by Neutrino Cruiser, Feb 28, 2007.
  1. Does anyone know of how I can relate the importance of the monostable
    multivibrator to day-to-day applications? I only know of its
    application in rising/falling edge detectors
  2. John Fields
    John Fields Guest
  3. JeffM
    JeffM Guest
    If you think *detection* is the most important part of that app,
    you have missed the entire point.
    http://www.google.com/search?num=100&q=monostable+stretcher
  4. Mr Grab
    Mr Grab Guest
    Neutrino Cruiser skrev:
    A mm. is typically used in pulse generators that is capable to vary its
    pulse width while the frequency remains the same. That is, if the mm. is
    capable to vary the hold time.
    Or, if the mm has a fixed time, the output frequency from the pulse
    generator may vary, and therefore the duty cycle 'll vary.
    Put simply:
    Pulse generator -> Monostable M. -> output
    And you are likely to put an schmitt trigger just after the mm. to get a
    clean pulse.
    Some useful links:
    duty cycle
    http://en.wikipedia.org/wiki/Duty_cycle
    http://www.idcmotion.com/pdf/9007.pdf
    Monostable Multivibrator
    http://en.wikipedia.org/wiki/Multivibrator
    http://www.play-hookey.com/digital/experiments/rtl_monostable.html
