I'm interested in measuring various parameters on a car - including
torque in the axle.
Is there a moderately simple way of doing this?
Breaking the shaft and sticking something in the middle is not an
option.
Is the best option to clean the shaft, and apply 4 strain guages, and
some means of measuring them and transferring the reading?
I see the usual methods for measuring shaft torque have been covered
in this thread already, triggering a thought which I will toss out for
your entertainment, not suggesting this is a good idea to actually do:
In the early days of IC (Internal Combustion) engine development it
was not uncommon to measure Indicated Horsepower (IHP) in addition to
Brake Horsepower (BHP). BHP is what you get from measuring output
torque and speed regardless of the means of applying load, and IHP is
a measurement of power delivered to the top of the pistons. Engine
losses are IHP - BHP. IHP was measured with an Indicator, which
consisted of a small piston-spring assemply such that the position of
an attached pen is proportional to combustion chamber pressure. A
card holder was geard to the crankshaft, such that it moved
proportionally to the engine piston position. With the engine at
steady state on a dyno the pen is dropped onto the card and traces out
the pressure vs displacement curve; measuring the area within the plot
with a planimiter gives net work delivered to the piston, the top of
the curve is the power stroke and the bottom is the compression stroke
which gets subtracted. Intake and exhaust in a 4-stroke engine shows
up as a straight line which is neglected. Multiply by power strokes
per second to get IHP.
Needless to say the old mechanical Indicator does not work with modern
high speed engines, but the same thing can be and sometimes is done
with electronic pressure sensors and crank angle sensors. Engines
already have the crank angle sensor, and last time I looked pressure
sensors mounted on spark plugs were readily available. So you could
measure IHP, characterize your vehicle on a chasssis dyno, generate an
IHP and RPM look up table for BHP from the dyno test data, and
calculate shaft torque from there
