MONITOR VIEWSONIC...STRANGE PROBLEM...
Discussion in 'Electronic Repair' started by Max, Feb 21, 2005.
  1. Max
    Max Guest
    Hi Having a monitor Viewsonic that had a blowed vertical IC . I had changed
    it , but now , without any signal , I should see a blinking "no signal"
    pattern but I see large vertical color lines (red/blue/green), like a signal
    pattern (color bar) but blurry.
    With a input , samething .
    The strange thing is when I turn off the monitor , I can see the picture for
    a quick moment.
    I had try to reduce the AC line , samething.
    Help !
    Thank...
    I ll post the model # later today
  2. Max
    Max Guest
    Vertical IC replaced is a TDA8172.
    By the way , is there any eprom inside the unit that can be corrupted ?
