Monitor starts bluish
Discussion in 'Electronic Repair' started by Volker Greulich, Jun 13, 2005.
  1. I have an Apple 20 Inch monitor, 6 years old.
    When I start in the morning all the sceen is looking light bluish.
    But after 2 hours it changes colors to normal.
    What is the reason? Where to look?
    Volker Greulich
  2. JANA
    JANA Guest
    This can be caused by some components in the bias and drive circuits to the
    CRT that have become thermo sensitive. As they warm up over time, they come
    back to be close enough to spec. I have also seen a CRT cause this before it
    starts to fail.
    An experienced tech, should be able to determine the problem for you, and
    give you an estimate. You may find that since the LCD screens are becoming
    so reasonable in cost, this should be the reason to do an upgrade.
    JANA
    _____
    Volker Greulich
  3. Rono
    Rono Guest
    These are a great (Sony) monitor! Likely to be just
    bad solder connections on the CRT board! Well worth
    fixing, especially, if it has a good overall picture. Rono.
  4. pranza
    pranza Guest
    Ah, if it's Sony, then don't pay attention to it. It's a very common
    problem. I've had a Sony G500 - it used to be greenish till warmed up,
    now I have Sony G520 (Dell P1130 to be exact) - it starts bluish but
    recovers quicker. I've seen more G500's and all they had the same
    problem, less or more severe. You may look here:
    http://www.short-media.com/forum/showthread.php?t=19549&page=5
