monitor problem "double image"
Discussion in 'Electronic Repair' started by [email protected], Aug 20, 2003.
  1. Guest
    I have this following problem and am wondering if anyone can help:
    Graphics card: All-in-wonder radeon 7000, 64 MB
    Monitor: Sony's trinitron based (not Sony), 0.25 dot pitch and 1280 x
    1024 maximum resolution, non interlaced. Horizontal scanning
    frequency: 30khz to 68kHz; vertical scanning frequency: 50 to 100 Hz.
    1) When computer first starts, no images come up on screen, I have to
    repeatedly turn on and off the monitor or wait for it to "warm up"
    before I get a thin (multicolour) single vertical line in the middle
    of the screen, then I have to wait and keep turning the monitor on and
    off to get the a full screen image.
    2) Once I have that (usually after about 5 mins), if I do get an image
    on the monitor, it would be a "double" image if the resolution is set
    to 1280 x 1024 (the highest resolution supported by the monitor). For
    example, if there is a "A" on the screen, there will be another less
    intense image of the letter "A" on the right hand side. Also, the
    faulty output can produce "vibrating" images, meaning the images are
    shaking left to right and vice versa. I have to go down to the next
    lower resolution (1152 x 840) for a normal display on the monitor.
    The shaking images can go either way: The shaky images become focused
    again , so I get a normal image display; or it keeps shaking until it
    remains as double images.
    Anyone know if this is a monitor problem or graphics card problem. I
    try using my system on another monitor. No problem there.
    Right now, I can only use the monitor at 1152 x 480 or lower
    resolutions.
    Any help is appreciated.
  2. Dave D
    Dave D Guest
    No easy answer without diagnosing it. Obviously the monitor has a serious
    fault which needs attention. If you play around with it, ie forcing it to
    start up you will almost certainly cause very expensive damage, perhaps even
    render it beyond economical repair. It appears to have a problem setting the
    correct scan frequency, you should not use it under any circumstances or the
    HOT and associated components and/or PSU will fail, no question. Not to
    mention the vertical line will burn in on the screen and ruin the CRT.
