T
Tim H.
Hello,
My dad's monitor decided to call it quits on him w/out any warning. It's a
no-name monitor with a Samsung tube and a ProView microcontroller. He did
say he heard a paper-rustling type sound before it went. I can only imagine
it was the flyback doing that. I go to turn it on and I just hear the power
supply cycling and the green LED on the front is flickering. I do a little
digging, check for obvious shorts (HOT, caps, etc) and discover that the HOT
is shorted. I yank out of the circuit and test it off-board -- she's dead.
Just for kicks, I measure Vec of the HOT while it was out of circuit and I
measured 62V.
Just for the heck of it, I did a little part matching and put in another
HOT, fired it up. I got the normal relay clicking sounds, heard the HV and
then it went to hissing, corona hiss? Almost like it's arcing inside the
flyback. Few seconds later, the HOT goes again as the power supply went back
to cycling.
Unplug the monitor, wait a few minutes. Check the filter caps, make sure
they're discharged -- all good. I look over the board for cold solder joints
or burn spots and I come across a relay with 6 of the 8 pins where the
solder looks like it vanished. I resolder it, put another HOT in and fire it
up. I get the normal sounds and it returns to hissing. I power it off and
there was a "poof" kind of sound and dust shot out from between the flyback
and the top of the PCB. It didn't smell so well either.
I'm certainly not trained to work on monitors/TVs, but I keep my hands away
from what I know is dangerous =) At this point, given the sound of the
flyback, I would almost say it's shorted inside. Below is a link of me
powering it up with the mic about 5" away. I then move the mic towards the
solder side of the flyback. The first "click" you hear is the power switch,
the rest are relays.
http://tekphobia.home.comcast.net/monitorhiss.wav (854KB WAV)
http://tekphobia.home.comcast.net/monitorhiss.mp3 (311KB MP3)
Tim
measured 62V.
to cycling.
Tim
