Molex Footprint
Discussion in 'Electronic Design' started by [email protected], Sep 29, 2005.
  1. Guest
    I'm looking for the footprint of the connector Molex 71436-1164.
    I use Allegro
    Giox
    gioparodi_forng1-templibero AT yahoo.it
  2. PeteS
    PeteS Guest
    I would advise you to do what the rest of us do: Get the print and make
    your own footprint.
    If you can import/export 3D models, then go to Molex, look up the part
    and select '3D models' from the left of the page.
    PDF footprint data here:
    http://www.molex.com/pdm_docs/sd/714361164_sd.pdf
    Cheers
    PeteS
  3. Paul Burke
    Paul Burke Guest
    Because there a gazillion PCB CADs available, each with a different
    component format from all the others.
    As the man said, get the data sheet and make your own.
    Paul Burke
  4. Giox
    Giox Guest
    Only a, maybe, stupid question....
    why the producer doesn't make available their footprint?... I think
    that they have them, in order to produce the components and test them.
  5. download the datasheet from the manufacturer, read the dimensions,
    build a footprint. Thats what the rest of us do.
  6. Giox
    Giox Guest
    Thanks everybody for the links and advices Gio
  7. Pooh Bear
    Pooh Bear Guest
    Because
    A. There are so many incompatible CAD programs that they would ahve
    tooffer lots.
    B. Not everyone even likes the 'stock' footprint and may adapt it to
    allow greater clearances, different drill sizes and special pads etc.
    Graham
