molex connector problem
Discussion in 'General Electronics Discussion' started by cpat, Jan 3, 2012.
  1. cpat
    cpat
    10
    Dec 14, 2010
    I bought a board with .100 molex headers, but no latching or means to hold the female receptacle other than the friction between the two, which is not much.
    So I'm seeking a way to hold the header onto the male pins.
    Any ideas?
  2. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    I have a lot of problems with Molex connectors. They're usually pretty helpful if you
    want to contact them.
    They make two types of connectors (your header), one with locking tabs, and one
    without.
    If the one you have won't stay connected, I'd looking into the same header with the
    locking tabs.
    Good luck.
  3. cpat
    cpat
    10
    Dec 14, 2010
    I'm no hardware expert, but I see nothing on the header to 'lock' to. I'm seriously thinking about wrapping a rubber band around the board and receptacle.
  4. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    You gotta buy the locking header and its mate for the PCB.
    Take a quick look at the Molex website and find what you've got and what you need.
    Molex is popular because they're relatively cheap.
    Take a few minutes to look at what else is available from them, then decide what you
    want to do.
    P.S. some rubber bands chemically interact with insulation on wires, and can screw you up.
    Also, if the vicinity of the board gets hot, your rubber band won't last long.
    If you just have pins on your board itself, it's not all that difficult to replace it with a
    locking connector.
    Good luck. I'd use the 'rubber' for other purposes.
  5. cpat
    cpat
    10
    Dec 14, 2010
    I purchased the pcb because of its function an accelerometer, which was my mistake. Not being a hardware expert, I didn't find out until later about the molex header, which was not identified in the literature as a molex, just .100 headers. The receptacle I had was out of another piece of equipment I owned which had died.
    If I need to buy another accelerometer, I will buy a dip chip not an SMT.
  6. (*steve*)
    25,482
    2,830
    A cable tie *might* work.
    *IF* there is a place either side of the connector where you can drill through the board without damaging traces, you can loop a cable tie around and hold it very securely in place. It's a real pain when you need to remove it in a hurry.
    edit: it sounds like your connectors don't match properly. Matching connectors hold on quite well. If yours can fall off, I'd be afraid that the electrical contact was poor too.
  7. cpat
    cpat
    10
    Dec 14, 2010
    I've come up with a solution. I've got some wires with single molex headers on them. Forgot I had them, but these have a tight fit on the headers. Problem solved!
    Thanks for all the help.
