I am in the middle of installing a whole garden irrigation system.
I want to build a controller for this, but need some kind of moisture sensor
It will be interfaced to a PIC with a simple high/low input
Any ideas on where I can either buy some, or plans on building them?
Sparks...
i've been trying to do something similar - i had a go a while back making
a soil moisture sensor using a pair of electrodes cast in a block of
plaster of paris, and measuring the resistance between. (the plaster works
as a buffer to stop soil salinity from affecting the resistance)
This didn't work so well - i was using galvanised wire, and i think it
corroded slightly so that there was a battery type circuit, and i was
getting a voltage off the sensor even when it was disconnected. The other
problem was there was a long time delay between the sensor going in water
and the reading stabilising.
But this is one of the well known ways of measuring soil moisture, so you
could try the same approach but with quite a small block of plaster
(maybe 2-3 cm on each side?), and some electrodes that aren't going to
corrode or react with the ions in the plaster.
The other way i thought of is to put some glass fibre tape through the
middle of a thin plastic pipe, bury one exposed end, and then work out
moisture by how far the water wicks up the tape to the other end of the
pipe.
Another possible approach would be to bury an unglazed ceramic pot in the
soil, arranged so that it is just filled whenever you water, and whenever
it rains. Then whenever the water in the pot has completely drained into
the soil, it's time for another watering.
for the moment i'm just sticking with a simple daily watering system with
a fixed amount of water.
