modifying a wall wart power supply?
Discussion in 'Power Electronics' started by thelectrifier, Mar 31, 2010.
  1. thelectrifier
    thelectrifier
    Mar 31, 2010
    hi, can anyone help me? a client needs a 7vDC 21w power supply for some gadget he bought.
    i have found a wall wart with 9vDC 25w output. can i just add a resistor in series with the output to get 7v?
  2. Mitchekj
    Mitchekj
    288
    Jan 24, 2010
    You'd need to know the exact current involved, or use a pot, etc. But, that would turn into straight heat. Not the best way to do it. Based on the power, you're looking at about 3A of current max? That'd come out to about 6W of power, that's a very large resistor, and you'd need some headroom over that. Heat sink, etc. I wouldn't go that route.
    The 'right' way would be to actually change the output. How to do that all depends on how the thing is designed. It could be as simple as changing the regulation circuit, or you may need to change other components, i.e. transformer, input cap, resistors here and there, etc. Most likely could not be done without a schematic and some good knowledge of power supplies.
    The most efficient way would probably be to buy the right adapter. :) Though, other people here may have a clever idea that I'm not thinking about, don't give up hope, hehe.
  3. 55pilot
    55pilot
    434
    3
    Feb 23, 2010
    Get the right power supply or build an external linear regulator. Using a resistor or a pot to reduce the voltage is a really lame idea that is not going to work in real life if the gadget's input current changes more than a tiny bit based on what is going on.
    Getting the right power supply is the simplest answer.
    ---55p
