Modern germanium diodes and transistors?
M
Mark Aitchison
Does anyone make germanium diodes or germanium transistors now? I think
I heard of some expensive modern germanium high frequency devices (but
I'm not sure if that was simply "a few decades old" instead of "many
decades old". There are some advantages with germanium in some
situations, but all the germanium diodes (for instance) I know of are
"new Old Stock" (or "Old Old Stock"!) and not particularly good in many
respects partially because of factors I guess germanium will always
have, but probably largely because the production techniques have
generally improved since then.
If somebody made germanium diodes or transistors today, could they be
much better, closer tolerance, less noisey, etc than before? Are
germanium transistors getting a bum rap simply because they used
techniques that also gave poor silicon transistors back then?
Mark A
Joerg
Says their 1N34 Ge Diodes are new but I don't know this company:
http://www.web-tronics.com/1n34.html
Then there is:
http://www.circuitspecialists.com/products/pdf/1n34a.pdf
AFAICT this diode didn't show up on Semtech's parts portfolio so I am
not sure whether they still make them.
R
RST Engineering \(jw\)
Whatever happened to "Oliver Germanium" and his company?
JIm
Joerg
David said:
A remnant of the company still exists, but only makes optoelectronics:
http://www.gpd-ir.com/products.htm
It surprised me that there wasn't a Russian company that took over at
least the production of Ge diodes. I could imagine that there would be
sufficient market size for a small enterprise to thrive on that. After
all, Svetlana has done just that for tubes.
