James Harris
I am looking for a way to write pieces of software to simulate the
'behaviour' of a resistor, a capacitor, an inductor, a diode etc. and
need a common set of parameters to communicate between the modules. Each
module would be one component. I wonder what would be the best
information for the interface between modules - i.e. for each component
to process and to output. I guess I'm looking for a common interface
between diverse components.
I don't think a simple voltage and current model is workable as I need
to account for the impedance of the supply. A simple resistor, if it is
low enough value relative to the supply impedance, will modify the
values passed to it so I cannot put, say, 3V across a resistor and
expect it to remain 3V.
My first thought is that I need to account for charge. If the component
is supplied
1) Potential across its terminals
2) Charge available
3) A time over which to calculate - say 1 microsecond
could it then 'reply' with the charge used (or, needed) in the time
interval?
Second thought is for the component to be supplied
2) A time over which to calculate
and it returns an instantaneous resistance. A capacitor, for example,
would begin with zero and increase to infinity as it charges.
In either case I need to modify the source of the voltage according to
its impedance and the circuit load. Please note that the intention is to
model the components over 'real time' so a static analysis of an AC
circuit isn't any good.
There must be a better way that I have described. I'm not even sure I
can get this to work. Any suggestions?
is supplied
2) Charge available
interval?
