Mobile network not available
Discussion in 'Electronic Repair' started by [email protected], May 10, 2013.
  1. Guest
    I am unable to connect my new phone.
    I suspect I have made a stupid, obvious error.
    When I tell it to search netowrworks it fails. When I tell it to select
    network automatically it seems to comply. But only if I do this will it
    switch from "Set airplane mode off" (ev'tho is off) plaint to "Mobile network
    not available"
    More on my setup:
    This Celfon http://www.everbuying.com/product298621.html
    (850/900.1800/1900) and this plan
    http://goredpocket.com/paygo-refills/e50.html (850.1900) says "Mobile network
    not available" but it sees the sim card as wap.cingular/att and it offers to
    see my balance on RedPocket. I checked that my acocunt is right in several
    ways.
    Vasos Panagiotopoulos, Columbia'81+, Reagan, Mozart, Pindus, BioStrategist
    http://www.panix.com/~vjp2/vasos.htm
    ---{Nothing herein constitutes advice. Everything fully disclaimed.}---
    [Homeland Security means private firearms not lazy obstructive guards]
    [Urb sprawl confounds terror] [Phooey on GUI: Windows for subprime Bimbos]
  2. Jamie
    Jamie Guest
    I just had a problem with my Razor phone sunday. It came up with saying
    no sim card detected and data detected..
    I first has to do a software reset.. That fixed the sim card problem
    but then my mobil network was screwed up.
    I then went to the mobile network set up and it was on global for
    what ever reason, which is not what it should be. I switched it to
    LTE/?? something, I can't remember now..
    But after that, I got my 4G back etc.....
    I still have no idea why it did that..
    Jamie
  3. Guest
    The Red Pocket (ATT reseller) SIM works fine on a "dumber" Motorola C139.
    So what is the cheapest plan that will work with the Feiteng Android A7100.
    I only want PayGO voice, I can use the net via WiFi, but i got useful Android
    apps I need to use.
    Much Obliged
  4. Guest
    I have the identical problem with Spot (T-Mobile).
    And I got the RedPocket sim to work with a Motorola C139.
    One new clue might be stanby mode, data mode, and/or dual-sim..
