Mitsubishi wt 46809
Discussion in 'Electronic Repair' started by [email protected], Apr 15, 2007.
  1. Guest
    I recently got a 46809 and when I went to turn it on, the power light
    goes on for 3 sec and then it turns off. Please help
  2. James Sweet
    James Sweet Guest
    What sort of help are you looking for? There's pretty clearly an
    internal fault which is being detected and the system control is
    shutting it down. If you have electronics diagnostic skills then someone
    may have some tips, but this isn't going to be something obvious like a
    fuse or switch, some digging and measurement will be required.
  3. Press menu and input simultaneously for five seconds and note the pattern of
    flashing on the LED and compare it to the info in the training manual. Then
    tourbleshoot the problem to determine where the fault is occuring. If you
    do not have the proper training and service literature, at least report the
    fault code and any measurements you have made. Otherwise get an experienced
    Mits tech to look at it.
    Leonard
