N
Never_Enough_Tools
Hi Group,
My Mitsubishi DLP TV shut off without warning last night.....Now it does
NOTHING....no lights, no sound, no anything. It is plugged into a surge
suppressor strip and everything else on there works fine. I also plugged
into another outlet just to be sure.
Won't go on by remote, front panel button, NADA ......
I pressed the little SYSTEM RESET button on the front, NADA.......
I bought this thing cause my last Mits TV is going on 12 yrs without a
hitch.....This one needed a lamp at 14mos, went out with NO warning (should
be one) --
Got the lamp replaced, then got the on screen lamp warning message 2 mos
later ????
Pulled the lamp, put back in, got the "did you replace lamp message", and it
was OK till now.
I'm sure these two event are not related, when the lamp went I still had
indicator lights on the front panel lit up.....As I said I've got NADA
now....help.......please....
Jeff
be one) --
later ????
was OK till now.
Jeff
