Mitsubishi TV Repair
Discussion in 'Electronic Repair' started by Jerry G., Dec 22, 2005.
  1. Jerry G.
    Jerry G. Guest
    Some components in the scan amplifiiers, pin amp, and convergence areas
    are starting to fail. Very commonly, electrolytic capacitors become
    thermo sensitive before they fail totally.
    If you are not trained in TV servicing, and do not have the facilities
    to troubleshoot TV sets, you should give the set out for proper
    servicing.
    There are also serious safety issues when working on TV sets.
    Jerry G.
  2. Jerry G.
    Jerry G. Guest
    servicing.
    Jerry G.
  3. Joe
    Joe Guest
    I have a 55" Mitsubishi, the problem is more so when it is first turned on
    the picture is distorted for a few seconds then is normal. It looks like a
    bow tie large on the ends squashes down to 3/4 the height of the picture by
    mid screen, the colors as you get closer the wide end of the bow tie
    separate so you can see the image in red , blue, and green like three
    separate images. Any ideas what might be happening?
    Joe
