Mitsubishi TV model CS-27EX1 vertical roll
Discussion in 'Electronic Repair' started by Lenny, Jun 30, 2004.
  1. Lenny
    Lenny Guest
    This set rolls for 20 minutes upon turn on and gradually settles down.
    I plan to esr all the caps in the vertical circuit but I have no
    schematic and was wondering if anyone has anything definite on this.
    Thanks, Lenny Stein, Barlen Electronics.
  2. Sofie
    Sofie Guest
    Lenny:
    If this set has PIP, do a google groups search for Mitsubishi PIP
    problems..... or similar search parameters. You will get lots of good hits
    and good repair suggestions including bypass and repair procedures for the
    PIP module.
  3. David
    David Guest
    I would double check, but I think this model had the PIP module that
    will have something like 28 bad surface mount capacitors on it. I am
    sure there are capacitor problems in the video input/tuner switch
    circuit near the switch ic on this model however.
    The vertical circuit capacitors on the ic vertical outputs usually
    cause foldover on top, some of the older Mitz sets it will cause
    vertical jitter on certain inputs.
    You need to look in the signal path or sync circuits first before the
    vertical output stage.
    David
  4. Sofie
    Sofie Guest
    David/Lenny:
    I have had plenty of Mitz televisions in my shop with vertical rolling that
    was caused by faulty caps IN THE PIP module.
    If it were in my shop I would do a quick bypass (2 capacitors) of the PIP
    module to verify where the problem is. Again, Lenny, go to google group
    search and enter Mitsubishi PIP Bypass, you will find lots of help. If the
    problem is in the PIP module then replacing the multitude of leaking smd
    electrolytics is the first order of business, however, if the module traces
    are very badly corroded because of the electrolyte leakage then you may have
    to replace the PIP module or talk the customer into a permanent bypass.....
    which for the majority of customers is just fine because many of them never
    use it, don't know how to use it, or are on satellite and can't use it
    easily.
  5. john
    john Guest
    "Watch the return E-Mail addy its false"
    Look for a bi-polar /\ /\
  6. Lenny
    Lenny Guest
    I bypassed the PIP module and that took care of the problem. Thanks to
    everyone who responded. I really appreciate it. best regards, Lenny.
