M
mr. bonez
I have this 27" Mitsubishi Tv and I read about the PIP board and have
heard a couple different things. I am interested in trying what this
post at the end of the thread here says about disabling the PIP board.
If I am reading it correctly I can get rid of the stupid pip board by
removing it and soldering a single cap to the mainboard. I don't know
why I haven't seen more posts stating this and wanted to make sure it
was correct. Also does anyone know where I can get the specific
capacitor the guy mentions there?
These are the caps that are known to go bad (some will go bad before
others). They are all surface mount types & they are:
C7001, 7003, 7011, 7014, 7015, 7016, 7020, 7021, 7023, 7026 & 7036. You
can usually see where the bad ones are because they will be leaking.
Make sure to clean up the leakage because sometimes it will eat away
the trace under the cap (which is known to happen under C7001). These
surface mount caps can be tricky to remove & if you're not careful you
can pull up a trace & break it.
If you (or your customer) don't use the PIP feature then you can bypass
it by removing the PIP module & soldering a 47mfd 50v bi-polar
electrolytic cap between pins 5 & 11 of the VP male connector on the
main PCB (I usually remove the VP male connector & then install the cap
in holes 5 & 11). Do not just push the leads of the cap into the holes
of the VP connecter because it won't hold up long term.
Mark
Mark
