Mitsubishi commissioning tool component identification
ADAM945
Jun 25, 2015
Jun 25, 2015
Evening all,
This is my first post here so please bare with me.
I'm after some help with identifying some components on a blown board.
Basically the unit I have here, is a commissioning tool for Mitsubushi air conditioning systems, (CMS-MNG).. In short, the role of this tool is to convert a 30vdc signal that is produced by an outdoor condensor to allow it to effectively "talk" to each unit.
Now before you connect this device to the outdoor unit it specifically tells you NOT to connect to anything above 200v.... Which as you can see has happened, which in turn has blown some components.
These units are expensive to purchase and my company asked if I could do anything with it.
Any opinions?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
I can 'bear' with you but I draw the line at getting naked!!
The only hope you have is probably identifying the larger SMT components, mosfets etc and attempting a replacement.
Good luck.
M.
ADAM945
Jun 25, 2015
Jun 25, 2015
Ha! ;)
uh huh LOL :)
DA could well be a BF622 Hi voltage NPN Transistor --- the package and SMD code match
http://www.nxp.com/documents/data_sheet/BF620_622.pdf
PCF1 "24" is an opto coupler for feedback from the output stage back to the input stage
This will be part of the voltage regulation circuitry
Davenn, I believe also the 'DA' could be a BF622 transistor! it matches the spec on the data sheet and also dimensions are correct, so I will order a replacement and try.
Any luck identifying the 56 29 transistors?
davenn
14,260
14,260
no, no reference to them
Ha! ;)
LOL you need to be careful how to spell words ... can lead to all sorts of misunderstandings haha ;)
bear = animal or to withstand
bare = naked bare skin, not painted bare wood or metal, etc etc
interestingly enough quite a common mistake by many people on the forums :)
