Mitsubishi 46" Projection TV powers on but no picture
Discussion in 'Electronic Repair' started by [email protected], Dec 12, 2005.
  1. Guest
    I aquired an older model Mitsubishi 46" projection tv that sounds like
    it powers on but there is no picture. I checked all the fuses of which
    no appeared to be blown. Any help and or ideas on how to fix it would
    be greatly appreciated.
  2. kip
    kip Guest
    Yes! Support you local TV Tech and give him a call
    ask him to come out and give you an estimate.
    Because all you have done is check fuses..
    What about the other components ?
  3. James Sweet
    James Sweet Guest
    Are the CRT heaters glowing? Is there audio?
  4. Guest
    There is nothing glowing and there is no sound. When the TV is plugged
    in and unplugged there is a small click. While it is plugged in when
    the power button is pressed there is a quick high pitched noise
    followed by a click.
    I was hoping to fix it myself but it seems it will need a tech to be
    repaired. I will probably just junk it.
    If it helps at all its model number is VS4503R.
    Thank you
