Jag Man
My remote no longer works well. The problem is the "Adjust dial"
(i..e, the inner rotational
control) will often act as if it's the shuttle ring. That is, rotation
of the inner control in order
to select a menu option causes the current selection to be Entered as
if I had
instead turned the outer ring. This make it impossible to do anything
with the menus
etc. I was once told this remote is no longer available from
Mitsubishi.
Can these things be repaired? If so is it a DIY task, or a repair
service company?
I also was thinking about replacing it with some kind of programable
aftermarket remote.
Which one would be best?
TIA
Ed
if I had
with the menus
Mitsubishi.
service company?
aftermarket remote.
TIA
Ed
