L
Lostgallifreyan
I already bought other means. Rubbermaid and hermetically sealed
plastic bags.
Rubbermaid? That doesn't sound quite right. >
plastic bags.
Lostgallifreyan said:Rubbermaid? That doesn't sound quite right. >
Frithiof Andreas Jensen said:Argh, wrong, Not NASA. The Army will know, Of Course!!
There *must* be a bunch of MIL-STD/Procedure(s) for storing electronic
equipment for many years (and still be sure that it will blow up when
switched on ;-) That's what the army *do*.
There was one person that said below 5% relative humidity could be damaging.
equipment for many years (and still be sure that it will blow up when ^^^^^^^^^^^^
Is there a minimum level of relative humidity, below which computer equipment is
damaged?
I bought some antique handheld computers. I want to keep them in pristine
condition for a very long time, fifty years or more. I want to know the ideal
environmental conditions to store these computers. I am probably going to store
these in a bank vault. I can greatly reduce the relative humidity using a
commercial desiccant such as drierite.
Thanks for your help.
I probably only need to store them for twenty years. That is about my remainingRich Grise said:Well, I've been following the thread, and it seems you really don't need
to "store" them for more than a year or five at a time, since later on you
seem to say... lemme check... No, I was wrong. I thought you had said that
you would be chacking on them every few years or so. But if not, why do
you need to store them for so long? 50 years from now, nobody will even
know what they are.
Rich
life expectancy. Who knows maybe I will live to be a hundred, then I need to
store them for fifty years. It looks like storing them in anti-static bags and
placing them in cans, filling the cans with Argon gas and a little desiccant,
would seem to be about as good as can be done. One nuance that I did not quite
completely get is that the desiccant might absorb many other things besides just
humidity.
Padding, anti-static-bag, and desiccant packets.Rich Grise said:Well, it can't absorb what's not there - you've just backfilled the cans
with argon; you might want to blow some argon through the units to purge
out any old oxygen, or do that vacuum trick, so what's going to be in the
can besides argon and the unit?
Rich
humidity.
Peter Olcott said:I probably only need to store them for twenty years. That is about my remaining
humidity.
John Jardine. said:Missed most of this thread but the British military just pack their
electronics in 2 heat sealed thick gauge polyethylene plastic bags (one bag
inside the other). No dessicants etc.
Last year opened up 1947 spy radio that had been repackaged in the early
50's. Condition was pristine. That's 50 years storage with little packaging
effort.
john
Jasen Betts said:as someone said you'll need to exercise the units every few years to keep
the capacitors alive. that means picking a method of packing that can be
opened conveniently. there are airtight reclosable metal canisters out there
(paint cans etc...) there are glass ones used for storing chemicals too, but
I'm not sure how either really is.
using an oxygen absorber as well as the dessicant is probably a good idea.
Peter Olcott said:What can I get that is an oxygen absorber?
What can I get that is an oxygen absorber? (I thought the purpose of the Argon
was to eliminate the oxygen).
Or maybe just pack 'em while in a warm environment.Peter Olcott said:[...]Missed most of this thread but the British military just pack their
effort.
john
I would guess that they might initially pack these in a minimum humidity
environment.
John Jardine. said:Or maybe just pack 'em while in a warm environment.
TBH, 50 years is actually a short time for storage purposes. Most objects
constructed of reasonable quality materials can be stored with minimum
degradation for many hundreds of years without any special treatment. The
big killer is damp and condensation.
Argon, Nitrogen, vacuums, dessicants, sealed copper containments etc are
fine for Expo buried time capsules, designed to be opened thousands of years
in the future but of little benefit over (say) a trivial 50 years.
I've a military radio collection and aquired over the years numerous small
electrical, electronic parts and assemblies. These range even back to the
1920s and '30s. Most of the bits have spent their lives in cheap paper bags
and cardboard boxes but have not suffered, as they have simply been kept dry
and indoors.
From the experience of getting these old boatanchors running again, I know
by that by far the biggest consideration to extending the life of electrical
equipment unused over a long period of time, is never, never, ever, allow
the equipment to be powered up at it's normal working voltage. Power needs
ramping up from zero to 100% over at least a couple of days.
john
John Jardine. said:by far the biggest consideration to extending the life of electrical
Michael A. Terrell said::
How about the plasticiser evaporating and turning the molded parts
into a crumbled mess of splinters?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
