Minidisk player
Discussion in 'Electronic Repair' started by Bobby Balsa, Dec 2, 2003.
  1. Bobby Balsa
    Bobby Balsa Guest
    Sony Minidisk problem: no record .Playback ok .
    Anyone has an idea? Thanks
  2. Sony Minidisk problem: no record .Playback ok .
    Is the record-protect switch on the discs engaged?
    Also, for MiniDisc to record, the laser must heat up the area to be recorded to
    its Curie point and an electromagnet on the other side of the disc actually
    does the recording.
    If the laser cannot engage in the power mode needed for recording, the disc
    will not record. If the electromagnet on the other side cannot deliver the
    magnetic pulses that it's supposed to, it can't record.
    Please give us more info, like what the player is actually doing when you try
    to record. Also, try other discs and, as well, check to see, like I've said
    before, if the record-protect tabs on the discs themselves are set. - Reinhart
  3. red
    red Guest
    Without specific model I can't help. Some MDs require at least something to
    be plugged into the line in or mic jacks for record to be enabled.
  4. CJT
    CJT Guest
    It could be broken, or maybe you're doing something wrong.
    Without a LOT more details, who can tell?
