Microwave Ovens
M
Madloot303
After repairing a microwave oven should I plug it in and test it to make sure
everythings in working order before I reassemble it?
S
Sam Goldwasser
What exactly can you test before you reassemble it? :)
If you mean, put the cover back on, depends on what you want to test. Even
if the magnetron is replaced, if properly installed there should be no
radiation leakage from within the electronics bay.
--- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
| Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: The email address in this message header may no longer work. To
contact me, please use the Feedback Form at repairfaq.org. Thanks.
A
Arthur Jernberg
Agreed, if in question of your repair expertise let an expert do the job
corectly the first time.
S
Sam Goldwasser
Astriapo said:
NEVER run a microwave with out the cover and after the cover has been
replace it needs to be tested for microwave leaks.
However, keep in mind that the outer cover is the second line of defense.
Unless the magnetron has been removed and improperly replaced, there
should be insignificant microwave leakage even with the sheet metal
cover removed.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
