Microwave oven temperature probe port grounding
Discussion in 'Electronic Repair' started by Tom Del Rosso, May 9, 2007.
  1. Just wondering what would happen if a metal container was used in a
    microwave, but grounded to the phono jack for the temperature probe.
    Assuming the connection was good, of course.
  2. bz
    bz Guest
    The 'grounding' would not help.
    A 'good ground' at microwave frequencies would be much less than 1/4 wave.
    The wavelength is about 3 cm.
    A good ground would thus need to be much less than 1/2 cm.
    A metal container is probably going to arc to the inside of the oven in
    several places.
    It may detune the cavity badly enough to present a high SWR to the magnetron
    and damage or destroy the magnetron.
    bz
    please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
    infinite set.
    remove ch100-5 to avoid spam trap
  3. The wavelength is too short for any effective grounding, and that is
    a 1/4" Phone jack, not a phono jack.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  4. Very interesting. I thought the wavelength was a few inches.
    So how does the probe get away with it?
  5. He meant to say 1/4 wavelength is around 3 cm. :) The wavelength is
    a few inches, like around 5 inches.
    --- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name AND either lasers or electronics is included in the
    subject line. Or, you can contact me via the Feedback Form in the FAQs.
  6. bz
    bz Guest
    Actually, I was thinking x-band radar was very close to the microwave oven
    frequency. I was wrong.
    The X band ranges from 7 to 12.5 GHz.
    The microwave ovens actually operate in the S band, the 10 cm radar band. The
    S band covers from 2 to 4 GHz.
    According to http://hypertextbook.com/facts/1998/HowardCheung.shtml
    most microwave ovens operate on 2.45 GHz which gives 11.8 cm wavelength, 4.6
    inches, for a quarter wave of a little over one inch or 2.95 cm
    In any case, it is still a bad idea to put any metal bowls into your
    microwave over, unless the metal object has been designed for use in a
    microwave oven.
    bz 73 de N5BZ k
    I fixed radars for a living in the mid 70's. I had a 1st class radiotelephone
    license, second class radio telegraph license with ship radar endorsements.
    infinite set.
  7. Ok, but the probe is over 6 inches long without the plug, so why doesn't it
    collect a charge? I always assumed it was because of the grounded plug.
