Alex Belenkiy
- Feb 2, 2015
- 5
- Joined
- Feb 2, 2015
- Messages
- 5
Good afternoon everybody,
my first question/post.
I am trying to repair a Frigidaire over the range microwave, it runs and counts down but no heat.
I have followed some troubleshooting videos from youtube to no avail.
Troubleshooting done so far:
Reset power to ensure it was not setting related.
Putting a glass of water in the microwave even for 5 minutes does not produce anything.
Opened the unit and tested each of the door opening switches.
Checked the high voltage diode for connectivity utilizing a 9v battery and tongue the voltmeter continuity test did not read it.
No components are burned anywhere.
Checked all thermal switches, NO and NC are all fine. I did not heat them to tripping point however.
Disconnected each high voltage part to test coil resistance and possible short to ground.
Tested the capacitor, it showed the proper uF as per the label.
Tested with a capacitor/diode set from an old microwave i took apart a long time ago.
The primary coil of the high voltage transformer gets 120V when the unit is running.
I do not have a high voltage voltmeter attachment to test the secondary side, but all of the coils seemed to be fine.
I do not hear the louder sound while cooking, leads me to the magnetron as the culprit.
Please let me know if i am missing anything in my testing, or what else i can look at or try.
thank you
Alex Belenkiy
thank you
Alex Belenkiy
