Microprocessor
Discussion in 'Electronic Design' started by [email protected], Oct 1, 2005.
  1. Guest
    I need to use a microprocessor for an application but I have only ever
    used microcontrollers in the past so I'm a little unsure about the
    whole microproccessor thing.
    I need to take some serial data, perform some maths on it, then put the
    new data out in serial form. The maths that needs to be done invovles
    exponentials to the power of 6, sin functions, sin^5 etc. The
    processor needs to go into a unit that will be hand held where current
    drain is an issue. Something that can be programmed in C would be
    great.
    Anyone got any pointers or tips regarding which family of
    microprocessor would be suitable to use. Or something to get started
    on?
    Cheers,
  2. Guest
    I would use a Palm OS based PDA as a development platform. Many use ARM
    processors, have serial I/O, and run on batteries. There is quite a bit of
    cheap help available for development on those PDA's.
    Once the software is debugged, you can easily embed the required
    hardware into your system.
    Jim
  3. Tim Wescott
    Tim Wescott Guest
    What do you mean when you say "microcontroller" and what kind of speed
    do you need to achieve?
    What you describe could easily be done with an 8051, or any other 8-bit
    microcontroller given sufficient time and enough program memory -- you
    could probably even keep it to 256 bytes of RAM if you didn't try for an OS.
    Without further detail you need something from 8 to 64 bits, that will
    consume between 0.01 and 1000 watts of power, with between 128 and
    128000 bytes of RAM, etc., etc., etc.
  4. Well,
    Guess you made the math thing insufficient clear.
    How many numbers at a time are we talking about? Three? Ten? Hundred?
    What is the data type? Byte? Int(2 bytes). Long or longer? Float?
    What accuracy do you need?
    What time is available? ms? s? hours?
    The principles are wellknown. The old micros did this kind of things
    already. The ZX81 for instance, used five bytes floating point math
    including the things your talking about. Microchip offers a -free- floating
    point math library including the functions you need... for 24 or 32 bits. If
    that package suit your needs, you only have to get a PIC with an onboard
    UART and do a little programming yourself. (Examples: PIC16F628, PIC16F873
    and PIC16F876.) Otherwise...
    petrus bitbyter
  5. Paul Burke
    Paul Burke Guest
    Sounds like you want to stick to a microcontroller. Depending on RAM and
    size of program, you might get away with an MSP430 (up to 60K flash, 2k
    RAM), or Zilog eZ80 flash parts (128k flash, 8k RAM), both creditably
    low power, especially in standby, both with serial ports and good C
    compiler support.
    Paul Burke
  6. Yeah. Go reread the textbook.
    Good Luck!
    Rich
