P
P L U M !
I need to build a preamplifier for a mic to connect it to a PC
soundcard. The mic I am using is a proffesional mic which uses an
electret mic capsule inside. I dont need to provide phantom power also
coz it operates on a 1.5V battery. Now, the plan is to build a preamp
with a female jack into which I can connect the mic's output jack. I
tried an instrumentation amplifier circuit which has three 741s in
it.The circuit worked fine for a gain of 10.
Although I could see a gain of 10 only when I put the mic real close to
the speaker.As I moved it farther the mic output(amp input) and also
the gain dropped.When I increased gain further, that is to 11 it worked
fine too. Then I increased it further to 20. Now the output of the
amplifier was zero! Then I tried to give a gain of 2 thru an additional
stage(a noninverting ampliflier using 741). So that would be 2*10=20
gain...But again the output was zero. Can anybody tell me where I am
going wrong???
The mic without any amplification showed an output range of 5-20 mV.
The link to the schematic of the insturmentation amplifier circuit is
given below:
http://www.allaboutcircuits.com/vol_3/chpt_8/10.html
going wrong???
given below:
