M
mike_94502
My Elenco MM-8000 microprocessor kit came with a bad ROM chip. After
pulling my hair out for many hours I finally went to an electronics
supply store an purchased a $3 ROM replacement chip, which worked
perfectly.
I'm posting this because others learning digital electronics with this
kit may be affected. The odds of getting a bad chip should be very
low which leads me to suspect Elenco has a bad batch of ROM chips in
their kit. I would hate to see someone give up on their project, like
I almost did, when the problem is really the chip.
The ROM chip is a 24 pin EEPROM. You can replace it with a similar
E2PROM with a part number containing 2816 or some variation. It
should cost $3 to $10.
Overall I like the kit, am learning quite a bit. I guess lesson
number 6.1 in this kit is don't trust anything and don't give up.
perfectly.
