microcontroller question
Hi
I am looking to build a prototype of some simple electronic equipment
involving a v. simple microcontroller, some on/off input and simple
output. I know some electronics and computer programming but nothing
about (PIC) microcontrollers or other embedded electronic systems.
Can anybody tell me of a newsgroup that might be best for this (if it
isn't this one)?
Where would I go if I wanted to pay someone else to make a simple
electronic system of this sort?
Thanks in advance
Russ
E
Eeyore
Hi
They're not *that* hard to understand if you have a decent working knowledge of
electronics.
isn't this one)?
sci.electronics.design
Ditto.
Graham
K
Ken Moffett
[email protected] wrote in
Hi
equipment involving a v. simple microcontroller, some
on/off input and simple output. I know some electronics
and computer programming but nothing about (PIC)
this (if it isn't this one)?
simple electronic system of this sort?
Thanks in advance
Russ
Russ,
You might try a PICAXE microcontroller.
http://www.rev-ed.co.uk/picaxe/
They are Microchip PIC's with an onboard interpreter. They're
programmed (free download sofware) in PBasic, and loaded
directly through a seriel cable from your PC. They're cheap
(relative to Basic Stamp micro's.), and have a lot of support
documentation, as well as two good support forums (one on the
company site, one on Yahoo), and several really good user web
sites. The also come in 8-, 18-, 28-, and 40-pin versions.
I've used the 8-pin chip in several projects to replace a lot
of descreet components and logic chips. Since you "know some
electronics and computer programming" these should work well
for you.
One caviat...these (and Basic Stamps) run on interpreted
basic, so run slower than the equvalent compiled language
programmed PIC.
Ken
jasen
isn't this one)?
this one is good for beginners, and maybe (much later) comp.arch.embedded
and sci.electronics.design for the really deep questions
If you want someone you can meet in person you could try the yellow
pages under electronic engineers. otherwise there are people here
who will do preliminary design of interesting problems here for free.
And same/others who will do contract work, most reqiure payment first,
such is the nature of the internet.
Bye.
Jasen
H
Homer J Simpson
Given more information someone might be able to point you to an off the
shelf solution.
B
BobG
Can anybody tell me of a newsgroup that might be best for this (if it=========================================
Check out Avrfreaks.net.... the atmel avr is the coolest 8 bit
microcontroller going... just ask any of the avt freaks themselves...
R
Richard Seriani
Hi
isn't this one)?
Thanks in advance
Russ
Russ,
If you are interested in PICs, you may want to look at www.microchip.com.
Lots of tutorials on the many hits you could get through Google.
For starters:
http://www.amqrp.org/elmer160/
http://www.mikroe.com/en/books/picbook/picbook.htm
Happy learning.
Richard
M
Mike_in_SD
[email protected] (Richard Seriani) wrote in <Qq7Xh.101529$mJ1.22476
@newsfe22.lga>:
while guys are throwing their favorite micro's at you let me give
my two cents.
http://forums.basicmicro.net/
the basic atom
its like the basic stamp .. on steroids
its only a little more expensive but has a ton of on board
stuff .. like A-D coverters, and servo drivers, etc etc
and its basic instruction set in the easiest I have seen.
just take a look
my two cents
mike
John
Russ,
for you.
programmed PIC.
Ken
I'll second this recommendation. I have a couple of useful projects
built with PICAXE chips:
http://www.picaxe.us/AV-fan.html
http://www.picaxe.us/WaterLevel-08.html
John
