Microchip compiling problem
kievari
Aug 31, 2010
5
Aug 31, 2010
5
being a novice I've had many problems with adopting a small test-driver of an LCD for PIC18F4550. Now much further from some days ago by the help of various great people of forums, but still get errors for things I don't know about the C18 compiler I'm using.
I'll provide the current error I have, hope someone help me go one step further with it. Also, I see in link statement "E:\mcc18\h", while I don't have such folder, but in "C:\mcc18\h", and I can't find from where in Microchip IDE to edit this.
I also attach the program and its other header files.
Code:
Release build of project `C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd4550.mcp' started.
Mon Sep 20 08:29:04 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.o".
Clean: Deleted file "C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd4550.mcs".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F4550 /i"E:\MCC18\h" "lcd-4550.c" -fo="LCD-4550.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:135:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:136:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:138:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:139:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:140:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:141:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:142:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:143:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:144:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:145:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:146:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:147:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:148:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:149:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:150:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:151:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:152:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:153:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:154:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:155:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:156:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:157:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:158:Warning [2054] suspicious pointer conversion
Executing: "C:\mcc18\bin\mplink.exe" /l"E:\MCC18\lib" /k"E:\MCC18\lkr" "18f4550.lkr" "lcd-4550.o" /z__MPLAB_BUILD=1 /m"lcd4550.map" /o"lcd4550.cof"
MPLINK 4.1, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - Configuration settings have been specified for address 0x00300000 in more than one object module.  Found in './lcd-4550.o', previously found in './LCD-4550.o'
Errors    : 1
Link step failed.
Release build of project `C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd4550.mcp' failed.
Mon Sep 20 08:29:05 2010
BUILD FAILED
Please help if possible! :D
  • lcd-4550.zip
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
It sounds like the compiler is case sensitive and you are referring to a module using upper case in one place and lower case in another.
It thinks that values defined in the module (windows is not case sensitive) are being defined twice.
Find where that module is references and ensure it is in the same case in all places.
