micro I/o lines
Discussion in 'General Electronics Discussion' started by Rajinder, Dec 16, 2016.
  1. Rajinder
    Rajinder
    531
    9
    Jan 30, 2016
    Hi all,
    I need to understand micro I/o lines for a PIC 18F.
    If I put a 10k pull up on a pin, and configure the pin as a input. It will read high. But if the same pin is set to an output, what happens? Also can I drive this low even though it has a pull up, by this I mean using the internal FET or open collector transistor inside the micro?
    Best regards
    Raj
  2. (*steve*)
    25,490
    2,831
    Unless something else pulls it (harder) to ground.
    The output takes the state you set it unless the pull up resistor has such a low value that the microcontroller can't pull it low. in addition, when you set the output to a low state current will flow through the resistor.
    Yes. If the output is open collector then this is the only way to get a high level on the output.
