Micro hydro-electric generator help
Discussion in 'Power Electronics' started by IATSB, May 28, 2019.
  1. BobK
    7,572
    1,633
    Given that we know the generator you have linked to will not provide sufficient output to do any harm, I can tell you how to wire it. Wire the + output of the generator to the + battery terminal. Wire the ground or - output of the generator to the - battery terminal. Done. It may put a tiny charge on the battery. It will never get up to full charge because it requires more than 12V to do that, but then it will also never get up to full charge because the power source is insufficient. If you are lucky, maybe 10 hours of charging will give you one hour of run time.
    I am serious. This is how you can charge a battery from a source that does not put out enough power to charge the battery in a reasonable time. This is how the solar garden lights that you see everywhere work.
  2. hevans1944
    hevans1944 Hop - AC8NS
    4,087
    1,940
    Jun 21, 2012
    Thank you for your service. My family also served, and some of us continue to serve today. I have the utmost respect for our military, who put themselves in harms way to help preserve our freedom and our nation's sovereignty.
    A combat engineer, as a trained infantry, is right up there along the side of non-combatant medics in their selfless dedication to getting the job done on the battlefield. But, and this is a huge BUT, no engineer blindly says "Let us try" without at least obtaining some of the education, experience, and training necessary for success.
    You did have a chance to try. It is too bad and so sad that your lame attempt was done without the requisite research to see if your approach was even possible, much less practical. That is not engineering.
    Early on, in post #15, @Tha fios agaibh posted a schematic. It used a 3-terminal voltage regulator, PB137, designed to charge a 12 V lead-acid battery chemistry (such as a sealed gel-cell or SLA - sealed lead-acid battery). His wiring diagram is essentially the same as the diagram (Figure 3. Application Circuit) shown on the datasheet. His diagram shows your water turbine generator providing input voltage to a PB137 regulator, an ammeter to measure the current delivered to a 12 V battery, and a pair of capacitors to "smooth" the brush noise no-doubt created by the generator. The input capacitor is 0.1 μF rated at 50 VDC. The output capacitor is 10 μF rated at 25 VDC and this would typically be a polarized aluminum electrolytic. I doubt you even bothered to investigate any of this, but it is the minimum circuit you would need to charge a lead-acid battery while manually monitoring the charging rate by observing the ammeter reading.
    Unfortunately, the wiring diagrams do not work for you because both depend on the output voltage and current you can obtain by trolling your water turbine behind or beside you in a boat. You will find that both the voltage and current available are woefully inadequate, but go ahead and try. Continue to ignore our advice and that of Master Yoda: "There is no TRY. There is only DO." The try may make you feel better and will not seriously inconvenience any fish.
    As for withholding information... it is you that did this from the beginning, not us. You didn't even bother to mention what water turbine generator you were considering using until post #28! What information do you think has been withheld by respondents to your original post? What have you done to learn about the problem and possible solutions to that problem? If you have a deadline to meet, it is your problem that you did not perform the research necessary to meet that deadline.
  3. Tha fios agaibh
    Tha fios agaibh
    1,866
    589
    Aug 11, 2014
    I didn't see and answer to my earlier question:
    Did you call the outfitter and ask if they can supply a boat with a marine battery?
    (Surely some boats have an electrical system to supply the required running lights at night)
    With your time constraints you probably can't fab up something on your own, but you might consider the crank dynamo I linked to.
    Perhaps not fun cranking until your arms are about to fall off while your buddies are sitting around the camp fire drinking Labatts.
    Or, consider Dave's solar panel option back on dry land and use the fish finder every other day?
  4. BobK
    7,572
    1,633
    I think he has "gone fishing."
    Tha fios agaibh likes this.
  5. GHamblin
    GHamblin
    Jun 6, 2019
    With a 10W generator delivering about 3/4 Amp you'll need around 10.5 hours with the boat in motion to charge your 8AH battery. I don't know how practical that will end up being.
