mic combination
Discussion in 'General Electronics Discussion' started by Sheikh Hassam, Mar 31, 2015.
  1. Sheikh Hassam
    Sheikh Hassam
    Mar 31, 2015
    What happens if we connect several mics in series or parallel? Are they increase the sensitivity of circuit?
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    This can be looked at in a similar manner to guitar pickups being wired in series or parallel.
    Ultimately, it will change the impedance or the 'new compound microphone' which will affect how it is amplified.
    Then you run into issues where the microphones may be picking up sounds out of phase to each other or picking up harmonics. You also cannot use any mic that requires power.
    What are you trying to accomplish?
  3. Sheikh Hassam
    Sheikh Hassam
    Mar 31, 2015
    i am trying to make a clap circuit which uses 741op-amp with 9v battery, i think that these combinations can increase its sensitivity.....can you please help me in making a highly sensitive clap circuit?
  4. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Well, to be fair. I have a gaming headset with a mic on it which is probably no more than 3/16" in diameter and it can quite easily pick up sounds throughout my room even if I don't want it too. Of course, if I turn up the amplification on it, you can hear even more!
    So instead of trying to build a microphone array, I think the better approach would be using a single decent quality microphone, a clean power supply, and a clean amplifier...
    Of course, I say this because I do not have any hands on experience with a microphone array. All I can tell you is a related experience with a guitar pickups in which wiring them in series or parallel may make the instrument sound 'warmer'
