Method to track shadow from light over a 5 cm sensor strip
Discussion in 'Sensors and Actuators' started by burt46, Jan 23, 2016.
  1. burt46
    burt46
    3
    Jan 23, 2016
    This is my first post as i'm hoping someone could help with my specific sensor problem.
    I would like to measure the speed of a shadow as it progressively covers a sensor area. The problem is that i need at least 5 cm of distance which a photoresistor doesnt give me. I have searched the internet and not found any sort of photoresistor or photodiode with a length of 5 cm. They are all round and up to around 1 cm.
    Does anyone have an idea if there is a sensor (ideally analog) that is in a continuous strip format to allow me to measure the shadow position accurately? Open to any ideas. A simple sketch is attached of the idea.
  2. (*steve*)
    25,363
    2,758
    Why not have two sensors about 5cm apart and measure the time between one sensor falling into shadow and then the next?
  3. burt46
    burt46
    3
    Jan 23, 2016
    Thanks Steve, but I cant do that as the speed varies over the 5 cm distance (the shadow changes as the light angle changes over the 5 cm distance). With two sensor is just get the start and finish times which i can use.
  4. (*steve*)
    25,363
    2,758
    Then use as many sensors as you need to track a number of points. I guess you could also use a linear ccd or even a ruler and a camera.
  5. Colin Mitchell
    Colin Mitchell
    1,418
    314
    Aug 31, 2014
    The ones on ebay give 1mm They cost $1.00 for 20. I hope this is not too much for you.
  6. burt46
    burt46
    3
    Jan 23, 2016
    Colin, good idea, but logging 50 sensors would be a pain in the backside if i can do it with one single data value.
    I may have the answer, which i am currently testing. House a single LDR in a tube with a slit down one side that is exposed to the light/shadow. The light entering the tube through the slit will change the photo resistor at one end. Bit cumbersome, but it may just work.
  7. Colin Mitchell
    Colin Mitchell
    1,418
    314
    Aug 31, 2014
    The problem you've got is the fact that a bright day at the beginning is the same as a dull day over half the sensor. That's why you can't use a single sensor.
    You need a "reference."
