P
PDRUNEN
Hi Group:
Looking for suggestions:
1: I have a light bulb load can be as low as 60 watts or as high as 600 watts.
The power source is the AC main at 120 Vrms 60Hz. I don't require knowing the
exact current, only if some current is being carried to the load.
I need to detect if circuit has current flow and these are some of the ways I
have approched.
1: low value current sense resistor into a comparator.
2: current-xformer: Very expensive and large.
3: Heating of the PCB trace carrying the current (maybe hard to determine for
all cases if the switch is outside in the cold etc.
Is there a hall-effect method or other method? IR sensor?
Must be something cheap and simple. So far only method one appears cheap and
simple.
Thanks Group!!!
Paul
have approched.
simple.
Thanks Group!!!
Paul
