Sreenath said:
hi,
how can we explain the metastability(first of all what is
metastability)in flip flops when set up /hold time is viloated.(cosider
flip flop architechture using pass transistors and inverters.)
Flip-flips are bistable structures, If you bias the input at exactly
the right voltage at exactly the right time, you can set the latching
transistors exactly at the point where there is no preference for one
state or the other. This state is - of course - unstable, but the
structure can take a very long time to fluctuate about this
"metastable" point to one side or the other to the point where it will
move progressively more rapidly to one or other of the stable
conditions.
In practice, if the latching structure is set close enough to the
metastable point that the nett current available to charge up the
transistor capacitances involved isn't high enough to allow the
transition to an outptu state within the guaranteed propagation time of
the device, people start talking about meta-stability.
See if you can find (or make) a device level Spice model of a
flip-flop, and have a play with that,
