I was looking at the cicuit diagram for a Metal halide Lamp fixture and curious how it works.
I see a step down auto tansformer with its tapped winding coneected in series with a 24ufd capaitor, then another winding (inductor), and then the lamp itself with the series return back to the low side of the auto transformer.
Both widings , autotransformer and inductor share the same laminated core. Do these two windings interact?
I realise the autotransformer is to lower the line voltage; in this case 480V, and the inductor (ballast) is for current limiting the arc once established.
How does the capacitor and inductor create the starting pulse to ionize the gas in the lamp. Is there a series resonance effect?
I calulae the 24ufd reactance to be 111 ohms at 60 Hz, how does this come into play?
