metal halide bulbs testing?
Discussion in 'Electronic Repair' started by Steve Vitale, Oct 29, 2004.
  1. Steve Vitale
    Steve Vitale Guest
    Hi all, I have an sharp XG-E3500U lcd projector that i'm trying to repair,
    I've purchased a copy of the service manual (email me off list if you'd
    like a copy) and have a pretty good idea of how things are working. when i
    got the unit, the main fuse on the power board was blown and the person
    who gave it to me suspected that the power supply was bad. when i replace
    the fuse and power up, the lamp arcs 2-3 but never lights. the fuse blows
    immediately afterward. my assumption is that either the warm-up arc isn't
    able to ignite the lamp because it's bad, or that the lower voltage
    componant supplied by the ballast is isn't there so the thing keeps
    pulsing then blows a fuse. Will a bad bulb cause a fuse to blow because it
    won't conduct a current after being hit with the warm up arc? I figured
    I'd send a message to the list to get an opinion before i spend $300 on a
    new bulb.. maybe i need to focus more on trouble shooting the ballast. Is
    there an easy check for visual or electronic signs of a bad metal halide
    bulb? Thanks for any help, Steve
    p.s., please don't warn me about the high voltage.. i may sound like a
    novice but my heart is healthy and i'm quite intent on getting this thing
    to work.
  2. NSM
    NSM Guest
    That's backwards. I'd suspect the ballast, not the lamp. Is the ballast
    inductive or solid state? I'd try hooking up a 100 W light bulb as a test to
    replace the lamp, disconnecting the starter system if possible. If the lamp
    glows fully or not at all I'd suspect the ballast.
    N
  3. Steve Vitale
    Steve Vitale Guest
    I assume that it's an electronic ballast as it uses transistors to limit
    current as opposed to a coil. i assume those should be keeping things
    from reaching a current where a fuse would blow? i think this is starting
    to make a bit more sense.
  4. NSM
    NSM Guest
    test to
    lamp
    | > N
    | Thanks
    Much more likely one of those has punched through. Replace them or find a
    way to test them under voltage.
    N
  5. James Sweet
    James Sweet Guest
    If the fuse blows you have a problem with the ballast. An electronic ballast
    still uses a transformer, it's more like a switching power supply in a PC,
    monitor, etc, but rather than regulate the output voltage it regulates the
    amperage as well as provides a high voltage spike to strike the arc. Check
    carefully for shorted semiconductors in the ballast circuit.
