S
Sam Goldwasser
I am trying to combine several small PCBs onto one panel.
Some of these were created with OrCad Layout and others with
Tango PCB+. The Tango files were imported successfully to OrCad Layout.
There are apparrently two ways to do this in OrCad - merge the .max
files or merge the Gerbers:
1. Merge the .max files.
Merging according to the OrCad help using Load command doesn't appear to
do anything useful. Either the second PCB doesn't show up or parts
on the open design change randomly. What's missing?
2. Merge the Gerber files.
This needs the aperture lists to match. What's the easiest way to to
this from different designs?
(2) seems like it would be better as the part numbering doesn't get
screwed up.
Or, can I go the other way - export OrCad .max to Tango PCB+ .pcb. All of
the designs are so simple that Tango would fully support everything.
Using OrCad Export requires the original Tango design to be present
which isn't terribly useful if the PCB was created in OrCad!
Any information appreciated.
And, no, changing to another layout package is not an option!
Thanks.
--- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
| Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: The email address in this message header may no longer work. To
contact me, please use the feedback form on the S.E.R FAQ Web sites.
screwed up.
Thanks.
