Melbourne Nylex sign
Discussion in 'Hobby Electronics' started by Heywood Jablome, Sep 13, 2005.
  1. Looks like the designers of the "new improved" Nylex sign should have
    consulted this forum as to how to wire a few LED's together.
    After a clunky start, (and dubiously blaming sattelite allignment for
    incorrect time) and only after a few months in operation, I noticed the
    other week that the E in NYLEX is no longer working. After a few hundred
    thousand dollars in updates, you'd think they'd do better than that!
    http://www.oneplusoneequalsthree.com/2005/06/our_nylex_sign_.html
  2. KLR
    KLR Guest
    Why would you run the clock only from the satellite ? having a local
    clock in case of failure would be more sensible, however common sense
    doesnt exist anymore.
  3. FruitLoop
    FruitLoop Guest
    Exactly , just have a PC synced with a time server
  4. Why would you run the clock only from the satellite ? having a local
    I bet that they do have a local clock, I reckon the satellite allignment
    thing was just a bit of an excuse.
  5. Alex Gibson
    Alex Gibson Guest
    Whats wrong with a realtime clock chip and a micro with battery backup ?
    Have an input from GPS to correct the time when available but no need for a
    pc.
  6. Ken Taylor
    Ken Taylor Guest
    A bizarre bit of make believe. Wonder if it was the clock's owners/operators
    or the commentators.
    Ken
  7. FruitLoop
    FruitLoop Guest
    Fair call , just thought a PC may do other things if required like remote
    control and data aquisition
  8. Alex Gibson
    Alex Gibson Guest
    So can a micro and doesn't use nearly as much power
    or need heatsinks etc
    Have a look at www.edtp.com using pics and avrs for wireless and ethernet.
