I am a newbie here and last time I did something with a circuit was in grad school. I am trying to build a simple circuit and can use your help.
Problem: Controling voltage so that the current is passed when certain threhold (for voltage) is reached.
I am using AerolCool Touch 1000, a fan controller which controls speed of a PC fan. The issue is that the fan is always on, it is either running at slow speed (RPM) or high speed when the temperature is hot.
I need to introduce some thing in the circuit (between fan controller and 12 V fan) so that the fan comes on when certain limit (read temperature) is reached .
I believe that the aerocool is simply controlling voltage and keeps on increasing or decreasing the voltage beased on temperature.
Any help is appreciated.
