Mechanism disassembly
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
I am not aware of a tool to be used to cleanly remove those...
A small flathead may be able to bend the teeth up to allow the caps to be removed, but the flathead may be damaged in the process, and the caps would need to be bent back into place before reassembly. (Possible that restoring the caps to 100% is not possible.)
Perhaps someone has seen a unique solution to these things?
Externet
Aug 24, 2009
891
Aug 24, 2009
891
Fit a tiny flat screwdriver in a radial gap and pry open as suggested above. By the second or third gap it will release.
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
I had a feeling you would have that problem. I have some tiny flatheads, but none I would carelessly use to try to pry those open.
Only other thought is an OLFA blade, but these can be brittle and snap. Not to mention they are very sharp. You can't get those out from the other side?
Externet
Aug 24, 2009
891
Aug 24, 2009
891
Plan B.
Hammer under the clip a knife and twist. Or insert a flat screwdriver as soon as there is any gap under.
Plan C.
Grab the outer edges of the clip with plyers and deform it squeezing.
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Plan B.
Plan C.
Your avatar is fitting. Brute force! ;)
I think that's all there is to it though
debe
Oct 15, 2011
278
Oct 15, 2011
278
They are a use once only part, you prise them off with a small screwdriver, then use a new fastener if you can find them.
