Measuring volt-amperes
Discussion in 'Electronic Basics' started by Fred C., Nov 19, 2004.
  1. Fred C.
    Fred C. Guest
    I have a spec for a furnace accessory that requires 2VA (volt-amperes)
    minimum from transformer (120VAC to 24VAC.) I can measure the 24
    volts, but how do I determine the volt-amperes? Many thanks.
  2. Louis Bybee
    Louis Bybee Guest
    The VA, or Volt Amp requirement has already been determined for you. The 2
    VA rating required by the furnace accessory you have is well below the
    capacity of most small transformers of the type usually used for furnace
    control devices. Assuming your device requires 24 VAC (quite common with
    heating systems) you should be able to purchase an appropriate transformer
    that mounts to an electrical box from an outlet supplying the heating trade,
    electrical supply outlet, etc.
    A simplified calculation of your situation would yield:
    VA/Volts= 2/24=.083 amps. Not exactly a high current device.
    Not knowing your skill level, or knowledge of such things, I would urge you
    to consult an electrical, or HVAC technician before actually engaging in
    your project. Quite often heating control devices (depending on the furnace
    type) are utilized to switch line level 120v or greater) voltage.
    Louis--
    Remove the two fish in address to respond
  3. Rich Grise
    Rich Grise Guest
    The transformer itself should have come with a specification that tells
    the maximum volt-amps it can provide.
    Good Luck!
    Rich
