T
Terry Pinnell
My beans on toast were not quite as hot as usual this lunchtime. I
suspect that I may have damaged our microwave recently (placing a
ready meal in a metallic container into it by mistake for a few
seconds) so that it's no longer delivering its spec of 650 W.
The following test seems to confirm this, but I'd appreciate a check
of my calculation please.
I poured 200 g of tap water into a small container. It was a thin
plastic container weighing 24 g, so I've ignored its thermal mass.
After a few minutes (while I fetched my DMM and a couple of
temperature probes) I measured the water's steady starting temperature
as 19 C. I heated it for 50 s and its finishing temperature was 43 C.
So the microwave raised 200 g of water 24 degrees C in 50 seconds.
I had to look up the Calorie/Joule relationship, which is that 1 cal =
4.1868 joules.
So wattage = (200 * 24 * 4.187)/50 = 401 Watts
OK?
I've been intending to replace this old unit with a more modern 800 W
oven for a couple of years, so it looks like the time has come.
4.1868 joules.
OK?
