MisFat wrote...
I want to measure the gate leakage current of a JFET. The only
measuring instruments i have is an old Tektronix scope and some DMMs.
I have read about Keithley selling meters to do this job, though i
want to design something of my own.
Fred and Phil have given you good advice. The leakage
current of a JFET's gate can be very low, less than 1pA
under the right circumstances. But be careful in your
measurements, it's a strong function of drain current
and drain-to-gate voltage. We have a detailed family of
curves in AoE, page 137, showing a 2n4868 with under 1pA
for Vds under 10 volts, but rising to 2.5nA for Vdg = 30V
and Id = 0.1mA, jumping by nearly 10x to 20nA for Id = 1mA.
In fact there's a region of operation where the JFET's gate
current is nearly 5uA. So you need to know how you want to
use your JFET in your design and adjust your measurement
scheme accordingly.
You may also want to modify your circuit configuration.
For example, if you use a second JFET wired in cascode,
with its gate to the first JFET's source, so the critical
JFET always has low Vds, you can enjoy a sub-1pA leakage
at any operating voltage and current. In fact, such an
approach can mean you don't even need to take the painful
low-current measurements! But one point, you'll need to
carefully choose the cascode JFET, because it must have a
high enough Vgs to give the lower one a reasonable Vds at
your desired current. While doing this be sure to keep an
eye on the wide part-to-part Vgs variation JFETs suffer.
One working example I have found, IIRC, the low-noise
BF862 can be nicely cascoded with an mmbfJ310. That's
just another factoid you can stuff away for later use.
