F
Frank
Hi Everyone,
What's the safest way to determine the magnitude and polarity of a DC
voltage?
Think along the lines of powering your DMM from your car battery.
Then trying to use it to measure the polarity and amplitude of a
cigarette lighter adapter. Also assume that the polarity of the
cigarette lighter socket could be either tip-positive or tip-negative.
Also assume the DMM's ground input is NOT isolated from the car's
ground.
(The above description is for illustration purposes, and was the best
way I could think of to describe my problem).
How do you not smoke things in the case of the adapter's polarity
dumping the full power into the DMMs ground (i.e. the car's ground)?
OK, I know I can optically isolate the inputs, but I'm not sure of the
best type of optoisolator to use. I'd be interested in measuring
voltages in the 1.5-15v range.
I had thought of using a bridge rectifier to insure positive to
positive and neg to neg, but with the low 1.5v requirement, the
voltage drop across the two diodes would be almost the entire minimum
voltage (1.5v).
I've seen some op-amp absolute magnitude and polarity circuits, but I
don't understand them enough to see how they'd work.
(http://www-micrel.deis.unibo.it/~benini/ELEI/Reading/AN-31.pdf, see
page 13).
Any insight would be appreciated!
-Frank
voltage?
ground.
voltage (1.5v).
page 13).
-Frank
