J said:
Another poster has the same opinion, too
then, back to original question:
It seems to be some problem to build equipment to measure over
+35...40dBm IP3 (at receiver input), do you know how it could be made,
or is it some references which might work?
7025 and 7050kHz tone frequencies would do
jm
Well, let's see. You want the 3rd-order product to be above the noise
floor of the receiver. Assuming a 10dB noise figure (you _will_ do
better, yes?) and a 5kHz wide filter a -120dBm signal will be just
discernible -- say you want it to be at least -100dBm.
With a projected intercept of 40dBm that gives you a 140dB difference;
dividing that by 3 gives around 47dB down from 40dBm, which means that
you need to feed about 7dBm into the receiver from each source (this is
sounding pretty absurd, I should just stop now).
Oh well, persevere:
I think the issue is that you need to have some very stout sources, and
a damn good hybrid combiner.
Not only do you need to make sure that each source's output won't bleed
into the output stage of the other source through the radio connection
and intermodulate there, you also need to make sure that note of the
energy from source A gets into source B and visa versa.
The "amateur" approach would be to make two sources each capable of
generating well over 7dBm (1W?) so that you can protect their outputs
with attenuators. If I were doing this as a garage effort I'd make two
identical crystal controlled sources, well shielded and operated from
batteries (rechargables, if I'm going to be producing a frigging watt each).
I have no idea what to tell you about the hybrid combiner, other than
you should pay attention to 3IM in the core, and test it.
Assuming that you have two good sources and attenuators, and a really
stout hybrid combiner, you should be able to get clean, high-level RF
into your receiver. At this point I'd take your RF (at what, 10 or
20dBm?), attenuate the heck out of it, and check the 3IM products. If
you get a 3IM product that tracks the attenuation linearly then your
sources or your combiner are at fault. If they track 3x attenuation
then congratulations -- you're actually measuring your receiver!
Good luck. Maybe I'll stick to NE602's -- the measurements are easier.
