Measuring current, beginner question
Discussion in 'General Electronics Discussion' started by reg2009, Jan 22, 2009.
  1. reg2009
    reg2009
    Jan 22, 2009
    I've got a very basic question about measuring waveforms using a true RMS meter. I'm trying to measure the average value of a current pulse. The current goes between 500uA and 2mA with varying duty cycle. Can I just set my meter to DC and expect an average value?
    Thanks in advance.
  2. neon
    neon
    1,325
    Oct 21, 2006
    Introduce speed and you got nothing.
  3. reg2009
    reg2009
    Jan 22, 2009
    Thanks for your reply. The frequency is relatively low. 5kHz or below I should think. Can you suggest a good method for getting an accurate average reading?
  4. neon
    neon
    1,325
    Oct 21, 2006
    now it all depends on the meter you see if it is slow then it become inacurate. And RMS is not an averge value .639 is the average but i might be wrong i forget sometimes. I think the DC will give an almost average if it is fast enough. some meters are digital some analog they differ in speed one is fast subject to noise the other slow and inherit a % offull scale error
