G
George
Thanks John and Peter for this great info.
I hope others will benefit as I have.
to do these great "schematic" sketches in your mail reader,
or is there a secret I don't know about that makes it easier ?
John (uvcceet)
snip
Now to see how the internal resistance of the battery affects the
battery output voltage, let's connect a 20000 ohms-per-volt analog
multimeter across the battery and see what happens. Let's say the
meter has a 10 VDC range. That would make its internal resistance
200000 ohms if we selected the 10VDC range and, with a 1 ohm internal
resistance for the battery we wind up with a reading of:
E1R2 9V * 200000
E2 = ------- = --------------- = 8.999955V
R1+R2 1R + 2000000R
See the voltage falling? That's because more voltage is being dropped
across the battery's internal resistance as it's required to supply
more current.
So far, with the voltmeter loads, the drop has been small, but it
starts to matter when you start drawing significant current from the
battery. for example, assume you have a 20 ohm load and that because
you've figured out that
E 9V
I = --- = ----- = 0.45A
R 20R
you expect the 9V battery to deliver 450mA into the load.
Well, if you look at
E1R2 9V * 20R
E2 = ------- = ------------ = 8.57V
R1+R2 1R + 20R
you'll find that, because of the battery's internal resistance you can
only get 8.57V across the 20 ohm resistor, which is only going to
allow about 429mA to flow through the load.
That's also borne out if you do:
E 9V
I = ------- = ----- = 0.42857...A
R1+R2 21R
:One thing that's interesting about it is that
:this way schematics can get archived as text files
:by outfits that don't archive binary files, like Google,
:and yet the data's there, and worth a thousand words.
: John Fields
Yup. What he said.
The name of the program Fields mentioned is:
Andy's ASCII Circuit by Andreas Weber
http://groups.google.com/groups?&q=andy's-ascii-circuit&meta=group=sci.electronics.*
As you hang around, you will see this appended to some drawings.
created by Andy s ASCII-Circuit v1.22.310103 Beta www.tech-chat.de
John,
R1 = battery internal resistance
R2 = meter internal resistance
Isn't the current increase due to the lower value of R2 (meter internal resistance)?
Why is R2 (meter internal resistance) not utilized here?
The meter is still connected.
The Load is a new type of resistance.
Shouldn't it be represented as R3?
More questions,
Your example with 20 ohm load shows R1 (battery internal resistance)
remaining at 1 ohm.
Your earlier post indicated R1 changes according to the load.
I may have missed something, but how do you measure R1?
Thanks for the program. I'm not familiar with the language, but I'm
guessing
"bne 120kR 12k" means branch to 12k if not equal to 120kR?
Does "bra end" in calci not terminate the program?
Wouldn't the program need to consider the factors you described in the
other post (R1:battery internal resistance and R2:meter internal
resistance)?
R2 and R3 are in parallel, and to determine the total resistance of
the pair we can write:
R2 * R3
Rt = ---------
R2 + R3
Where Rt is the total resistance of the pair.
For your digital multimeter, with a 10M input resistance we'll get:
R2 * R3 20 * 10E6
Rt = --------- = ---------- = 19 999 960 ohms
R2 + R3 20 + 10e6
and for the 20,000 ohms-per-volt analog multimeter we'll get
R2 * R3 20 * 200000
Rt = --------- = ------------- = 19 998 000 ohms
R2 + R3 20 + 200000
Watch those pesky periods! That should be 19.999 960 ohms
current through the load and then, using Ohm's law, calculate what the
resistance should be for that current if you had the full battery
voltage across the load. The difference between that resistance and
the actual load resistance will be the internal resistance of the
battery. Also, the difference between the measured voltage and the
full battery voltage multiplied by the current should be the internal
resistance of the battery. That is, both readings should be the same.
I think...
The next to last sentence "Also, the difference between the measured
voltage and the full battery voltage multipied by the current should be
the internal resistance of the battery."
Shouldn't "multipied" be "divided by"?
Yup...
I assumed that modification to agree with Ohm's law where E is divided
by either I or R. I'm calling this sentence "Method B".
On my first test,
E full = 8.18 volts.
R load = 118800 ohms.
The meter shows I readings of .05, .06, and .07 mA alternating.
Do better meters show more precision?
Using .05mA, the Battery IR is 44,800 ohms by method A, 400 ohms with
method B.
Using .06mA, the Battery IR is 17,533 ohms by method A, 333 ohms with
method B.
Using .07mA, the Battery IR is -1943 ohms by method A, 286 ohms with
method B.
Considering that an alkaline 9v battery's nominal internal resistance
is 1.7 ohms, are these numbers reasonable?
Why is Method A very different than B?
At http://www.kadentech.com/ they offer Model 3365 to actually measure
battery Internal Resistance. It costs about $500.
The maximum reading is 39.99 ohms.
Why would such an expensive meter not be able to read the IR ranges in
our tests?
I noticed that in my test, there was a difference of only .02v drop
(8.18 to 8.16) when load was connected.
Your battery showed a larger .82v drop (9.00 to 8.18).
Any idea why this difference?
As a beginner at this, I'm a little confused.
